how much can my transmission handle?
Old Jun 25, 2006 | 09:01 AM
2strokefreak's Avatar
im trying to put a 450 hp motor in my car its a 91 rs im wandering if im going to have to get a different transmission for the power or rebiuld this one or something. its got the 5 speed manual?
Old Jun 25, 2006 | 09:36 AM
angel71rs's Avatar
Re: how much can my transmission handle?
Stock T5 will not live behind 450 hp. I used to have a link to a company that beefed T5s to take big power, but I can't find it. Might check in the drivetrain section. You could also go with a T56 swap.
Old Jun 25, 2006 | 12:41 PM
89Vert's Avatar
I take out T5's with my 305,l
but I've heard of guys running 383's on a T5
hp isn't the problem it's torque that'll kill it,
450 is alot of hp, what combo are you running
Old Jun 25, 2006 | 01:16 PM
respectirocz's Avatar
g-force transmissions sell upgrade kits for the t-5
the stock t-5 is supposedly rated at 300 ft-lbs of torque
if you are making 450 hp on a chevy small block, then you are definately putting out over 300 ft-lbs of torque
easier than getting the stock t-5 rebuilt with the g-force upgrade kit, is switching to a t56 transmission, which can handle somewhere around 450-500 ft lbs of torque
Old Jun 26, 2006 | 12:07 AM
http://cgi.ebay.com/ebaymotors/NEW-G...00377907QQrdZ1
is that what i need?
and do i need to do anything else to my driveline?
and where can i get this t-5 upgrade kit seems it would be easier to just upgrade the one i have?
Old Jun 26, 2006 | 06:29 AM
Dave89IROC's Avatar
http://www.g-forcetransmissions.com/tran_gt-5.asp
Old Jul 5, 2006 | 01:47 PM
1987IROC350's Avatar
The one on e-bay would not hold up. Its in the ad that it is good for only 400lb/ft torque. I have a motor with 430lb/ft and 425HP. So your motor with 450HP should certainly have 450lb/ft. I upgraded to a Punisher 700R auto that is good for 500HP from
http://www.maddog-transmissions.com
Old Jul 7, 2006 | 01:12 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
You know, just because a transmission is rated for 300 or 400 or 500 torque, its not going to blow up if you have 1 more than that rating. The rating is a general idea based on the relative strength of the transmission, as judged by the manufacturer. Also keep in mind, the rating is based on street tires and a stock clutch. Put sticky tires and a performance clutch in there, and the rating of the trans goes down considerably.
My stock T5 lasted thru 3 years of 400+ ft/lbs of torque at the wheels, with ET Streets and a McLeod clutch. Until I started running 12's. Then it broke on the next pass. My T56 has lasted thru the same abuse for another three years with no problems. Your results may vary.
Old Jul 7, 2006 | 12:16 PM
white/blackss's Avatar
put a turbo 350 in there, best move i ever made. my car had a liberty tremmac t-5 and has run a best of 10:62 1/4 with the t-5.
that trans cost me 700 dollars to have built. i since have put in a turbo 350 and it has proven very low 10sec 1/4 times. im glad i swapped and ill never look back
cmsmith
Sep 14, 2015 09:25 PM
cohopefull
Sep 8, 2015 03:22 PM
LazyLemming
Aug 29, 2015 07:36 PM
Slayer
Aug 17, 2015 03:55 PM
Cam's maro
Aug 11, 2015 07:45 AM
