How to gut airboxes
Old Dec 5, 2004 | 01:53 PM
camarokidirocz's Avatar
Exclamation How to gut airboxes
how do you gut the air boxes on 89 tpi's and how do you get more airflow
Old Dec 5, 2004 | 07:25 PM
82355's Avatar
Re: How to gut airboxes
Take the Y snorkel loose from over the air filters and from the MAF. Set the snorkel off to the side. Remove the air filters. Use 7mm socket or nut driver to remove four screws holding the water baffles down (4 srews under air filters). Cut out the remaining baffles under the air filters. Reassemble.
For more airflow some people run tubes from the bottom side of the air filter down to behind the grille (where the foglights are if you have them).
Also in your sig, you don't bore a 350 block to a 383. You stroke it, (along with an inconsequentiall .030 overbore)
Martin
95mysticta
Aug 20, 2015 07:43 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
formula218
Dec 2, 2014 04:27 PM
IROC5.7TPI
Sep 8, 2002 10:48 PM
