Stealth Ram AFPR
Old Dec 1, 2004 | 07:19 PM
Bristol's Avatar
Stealth Ram AFPR
Can someone either send me a link to or explain to me how to get the AFPR into the general ballpark. I got my AFPR and the set screw is full clockwise. I need to know roughly how many full turn is needed to get into the general ballpark? Thanks in advance
Kris
Old Dec 5, 2004 | 08:20 AM
mrr23's Avatar
Re: Stealth Ram AFPR
well if you have it bottomed out, your most likely well above 60 psi.
Old Dec 5, 2004 | 03:16 PM
jaykar's Avatar
Hi,
What you really need to do is get yourself a fuel pressure
gauge so you know where your at.
Doesn't have to permently installed if you get a portable.
I just use a Snap-On with the adapter to plug into the fuel
rail.
I just don't like using the inline as don't trust them for the
street n leaks or broken lens or needles.
Just my experience from the past.
Get a gauge however.
Later
jaykar
Old Dec 5, 2004 | 07:34 PM
Bristol's Avatar
I tried this and it seems to be fixed. At least according to 2 seperate rail mounted liquid filled gauges. I had issues with my AFPR not wanting to hold pressure. I turned the AFPR all the way to max pressure. I clamped the return line and primed the system...it would hold pressure until I unclamped it and then immedietly bled to 0psi. I repeated this a few times to see i perhaps I had a leak to no prevail. I then clamped and primed 3 times with pressure well over 60psi...unclamped and it finally held pressure. I turned the screw down til it read 45psi. Re checked in 30min. later to show 40psi. 8 hours later 30psi. So Now it shows the regulator is regulating pressure. Im gonna try starting it tommorow if I have time and when its running Ill make my quick adjustments to pressure. Thanks for the input.
Kris
G-BODYT56
Jan 14, 2022 11:14 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
zk06
Sep 9, 2015 11:39 AM
