how do u disable speed limiter
Old Jan 21, 2004 | 05:58 PM
  #16
Zepher's Avatar
Originally posted by Ville H. Valo
Can you burn me one that would be the same as a Hypertech, for a 1992 TPI CAmaro Z28 5.0?
Ya, but for your car you need to have an adaptor that looks like this,
The adaptor sells for $61 shipped with 2 blank proms, so for $111
I can do your car as well. I'll do lifetime burns of the chips, all you cover is shipping both ways for the proms which is about $1.25 each way.
Old Jan 21, 2004 | 06:40 PM
  #17
Ville H. Valo's Avatar
if i bought a hypertech chip the adaptor comes with it, right?
-Ville H. Valo
Old Jan 21, 2004 | 06:48 PM
  #18
Zepher's Avatar
-Ville H. Valo
No, if you buy the hypertech, it is already in a memcal like your stock one. they just erase a stock memcal and re-program it.
JET chips use an adaptor, which is what I posted a picture of.
I don't have a pin adaptor to reprogram a chip that is still in the memcal, and using the adaptors is much easier especially when using flash chips which can be erased in seconds in the programmer. Chips in the memcal are Eproms which require the use of a UV light prom eraser.
Old Jan 22, 2004 | 12:51 AM
  #19
SSnthe10s's Avatar
HIGHJACKERS!
Old Jan 22, 2004 | 01:05 AM
  #20
chevyman502bb's Avatar
I used to have a 1989 Camaro RS w/ a 2.8, it would shake at 85mph but would stop around 100mph. try balanceing the tires...
-Ville H. Valo
driveshaft also
Old Jan 22, 2004 | 05:24 AM
  #21
aklim's Avatar
Check engine and especially tranny mounts. Ask me how I know.
Old Jan 22, 2004 | 07:16 AM
  #22
Black6SpdTA's Avatar
There is a tech article on www.thirdgen.org for a toggle switch disabling the VSS sensor. Or just take the plug out.
-Corey
Old Jan 22, 2004 | 12:14 PM
  #23
aklim's Avatar
-Corey
Yes but that disables cruise control. However, is that all? Will it screw up the ECM calculations?
Old Jan 22, 2004 | 12:15 PM
  #24
Zepher's Avatar
Ya, I hate not having cruise control when driving 110+
Old Jan 22, 2004 | 05:58 PM
  #25
That's exactly what I was thinking.
aklim, it doesn't screw anything up, how fast you're going doesn't deal much with the ECM calculations. Fuel tables and stuff are dependent on RPM right? In that case, speed wouldn't matter.
Old Jan 22, 2004 | 06:06 PM
  #26
Zepher's Avatar
only thing I can think of is the TC not locking up since there is no speed reading.
Old Jan 22, 2004 | 10:35 PM
  #27
aklim's Avatar
I have set CC at about 120 once.
Not sure what would happen if the TC did not lock up but I would imagine your RPM would be higher?
Old Jan 23, 2004 | 01:31 AM
  #28
dj haf's Avatar
my iroc-z came with a speed limiter at 120 mph.
i noticed when the vss is disconnected and the speedo stops working, the engine revs a couple hundred rpms' higher
Old Jan 23, 2004 | 07:51 AM
  #29
Pro
Guest
Posts: n/a
It's not a computer controlled transmission though right?
Even the 4L60E in my truck locks the TC when my VSS fails (constantly for some reason....)
What code will be displayed when the VSS in the camaros is disconnected (if any)? I wonder if this is the check engine light I get sometimes when I am driving, but it is never stored.
Old Jan 23, 2004 | 10:05 AM
  #30
aklim's Avatar
I don't think the tranny is controlled by the ECM in that the shifting is controlled by hydraulic pressure but I believe the lockup definately is.
