how do i know if im in overdrive?
Old Aug 26, 2004 | 05:43 PM
CamaroZ28Coupe's Avatar
(700 R4) is there suposed to be a light that comes on? or is overdrive just 4th gear
is that the same as the lockup in the torque converter
Old Aug 26, 2004 | 08:18 PM
87DJP2001's Avatar
Re: how do i know if im in overdrive?
With a 700R4 you are in OD when its in 4th gear (no light), you will also note a drop in RPM's. Example: 40MPH in 3rd will have about 2500 RPM's and when in OD @40 MPH the engine will turn 1000 RPM's.
Old Aug 26, 2004 | 11:51 PM
yep, i get the rpm drop and i know its 4th just wondering what that little circle in my speedometer was for
Old Aug 27, 2004 | 02:26 PM
88Irocker's Avatar
Is that the blue light for the high beams?
Old Aug 29, 2004 | 05:55 PM
yea highbeams,
how do i know if the torque converter is locking up corectly?
is that just what 4th is?
i ask to make sure becasue i heard that it can be damaging if it doesnt lock up
Old Aug 29, 2004 | 07:26 PM
88Irocker's Avatar
When you're up to speed and in overdrive (40+) nudge the throttle a bit, but not enough to make the trans downshift. Watch the tach, if it jumps up a couple hundred RPMs, the converter is not locked up. If the tach doesn't really move, and you should be able to feel a little "kick" from the acceleration, then the converter is locked. 4th is Overdrive and is not the same as the converter locking up.
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
BLK1997Z28
May 7, 2015 03:01 PM
jb4xx
Feb 2, 2015 10:00 PM
Z28-CTYHNTR
Jan 20, 2003 03:29 PM
