How can I find damper diameter?
Old Mar 19, 2004 | 05:28 PM
StealthElephant's Avatar
I measured my dampers circumference and it was 21 inches around. So 21/Pi = 6.68". Thats CLOSE to 6 3/4" but not quite....should I assume it's 6 3/4 or what? I need to know the diameter...is there a more accurate way? My only options are 6", 6 3/4" and 7"...so it's gotta be a 6 3/4" right?
The engine is in the car, the pulleys are the in way.
Old Mar 19, 2004 | 10:26 PM
OneSickS10's Avatar
I'd say 6 3/4" (6.75), either that or roll under there with a right angle ruler. and see if you can get a more accurate reading with that. How did u measure the circumference? String?
Old Mar 20, 2004 | 03:42 PM
Damon's Avatar
Yes, it's 6-3/4 inch type. They aren't exact in their diameter. An 8" would be obviously bigger. If it's the original engine in the car then it's definitely the 6-3/4" type. That diameter was used in all 3rd gen motors.
Old Mar 20, 2004 | 04:06 PM
It was a 350 truck motor, 70s.
But it's almost definately 6 3/4?
Victor Lamb
Aug 26, 2017 02:52 PM
mongoose=
Mar 22, 2015 07:22 AM
mschmidt33
Mar 15, 2015 07:20 PM
zxtce
Mar 12, 2015 08:06 PM
Jul 4, 2005 05:00 PM
