Is the "HOT" cam a decent choice for my combo?
Re: Is the "HOT" cam a decent choice for my combo?
Originally Posted by V8Rumble
Now that's just ugly - to spend around $1500 on a new set of heads, only to need to spend another $600 or more replacing the parts that should've worked in the first place...Based on what it sounds like you're saying, buying new heads isn't necessarily the smartest move you could make...
Like small-block Chevys need any help screwing up valve seals...
Well, when you put it into terms of rebuilding the freakin' thing anyway, then all you're really looking at is a chunk of cast metal - the same as an intake manifold!
(OK, two chunks...) I suppose that the only things you'd need to beware of are instances where the previous owner went nuts with a die grinder (probably pretty obvious,but sometimes not, if they just ported it so that the flow is sub-optimal...) or warpage issues where one of the sealing surfaces is no longer flat (which should be fairly easy to check for when you get the heads). I don't know if you could even tell if there were issues with porosity/bad casting/etc...
Am I forgetting anything?
Right. If it were me, I'd buy a bare set or used set and put whatever I want on it. I was at the stage where I had to buy everything new. If you have time, shop around and see what you can get.
If there is a second groove there on the valve stem it WILL rip the seal off in under 20 miles.
Correct. So why buy new?
Warpage is easy to check for. Run a straight edge over it. Also, check around machine shops. Quite often they have heads lying around were the customer has upgraded and they bought it on trade. Get it from a reputable shop tho.
Originally Posted by onefastgta
...There is no such thing as a computer cam, mine is 242-254 @ .050 duration and 110 lsa and it runs fine after tuning, it all depends on who's calling the shots.
You can run a modded car with the stock chip, my car ran fine with a 383, afr heads, small crane compucam, slp headers, and stock tpi intake with the stock chip. Was it optimal, no, did it work fine, yes.
rephrased, "Is it optimal, no, does it work fine? Yes."
No error codes, no problems. I had expected problems with all the modifications.
GM stock HEI distributor
Stock Runners
Exhaust stock from collector to tail pipes.
- Crane Cams FireBall HI-6s ignition system w/XL92 external Coil, and 8.5mm Firewire Spark Plug Wires.
- ported GMPP aluminum 62cc fast burn heads
- ported SDPC high-flow TPI Vortec Intake
- Ported GM TPI plenum
- Stock T-Body bored to 52mm with air-foil installed
- deleted T-Body coolant system, not bypassed, but completely removed.
- Removed MAF screens.
- Accel 30lb/hr injectors
- Holley AFPR
- Holley 225/LPH fuel pump.
- SLP 1-3/4" emissions headers to 3" collector with y-pipe.
- 170° Thermostat
- Edelbrock high-flow aluminum water pump.
Bottom: - Forged Alumimum JE-SRP 4.060"x1.125" -16cc dished pistons
- Scat Series 9000 Cast 3.75" crank X 6.000" rods.
- ComCams XE262H-14 218/224@ 0.050"/114°LSA Mild street cam.
Originally Posted by aklim
Look. I bought a set of AFR heads and they were new. However, I exceeded the lift they specified when I switched to 1.6 ratio RR and that was bad because there was now some valve float when I beat on it.
Just because I escaped it with some scuffing of the tips of the valve by being stupid and going 20 thousands more than they said I could, doesn't mean you will be as lucky. You can profit from that experience since I have paid for it already and be money ahead. Now, if you buy a set of AFR heads and stick below what they say is the max lift, you should be ok. I wouldn't push the ragged edge if that is the case.
I would go say 30 thousands below what their max is. Do you feel lucky, punk? Well, do you?
I think I get what you're saying, & we're in total agreement...
The alternatives that I've had in mind were the GM Fast Burn heads, the 'Pro Topline' units, or maybe Dart/Brodix, which might be a bit cheaper. Only "problem" (??) might be the fact that I wanted to preserve the L98 angle plug setup, since I'm already familiar with that setup with my headers...
Thanks again for your thoughts, it's good to hear from someone who's been there.
Originally Posted by raul.garcia
I built my 1988 IROC MAF TPI 388/6.4L stroker 350 sbc to run on premium pump gas with a functional stock emissions system. (Cat, air pump, and EGR.) I'm started with the 1227165 ECM $6E 89' AUJL prom bin then changed to the 89' ARAP with only the injector size, and fan operation modified on both until I learn to tune.
YEAH - that's a real good idea. Especially since the bare AFR heads I was looking at were only about $150 less than the "complete" set when I called AFR to price them...
One word of caution. Brian Ebert might start to talk over your head and you have to be careful to stop him and question him as he assumes you know what he knows. He is very knowledgable tho. He has lost me a couple of times and I had to backtrack him so he would explain it to me. For instance, he assumed I knew why he wanted a mix of 1.6 and 1.5 ratio RR. I had to ask him why and he had to tell me that it was to prevent reversion.
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
