help!..removing bolt from block
Old Dec 29, 2006 | 12:54 PM
Wishmaster's Avatar
I need to relocate my Knock Sensor to the drivers side of the block cause of the 2210 long tubes...when I went to try and get the bolt out it stipped all to hell!....and now I cant get it out.
any ideas on how I can get it out?
Old Dec 30, 2006 | 11:13 PM
DarkJuggalo's Avatar
i broke off a header bolt on my block. had to pull the block and have a machine shop get it out =\
hope u can get it a diff way, maybe drill a pilot hole and reverse it and hope it unthreads the bolt? that worked on a couple bolts b4 for me.
Old Dec 30, 2006 | 11:24 PM
ringo234's Avatar
You can drill a hole but instead of reversing the drill use an easy out it's sort of a tappered tap with reverse threads. The more you tighten it, the more it trys to remove the bolt. It might work.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
