HELP!! pulling intake off of a 91Z TPI, what mods can i do?
Old Jun 13, 2002 | 08:25 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Exclamation HELP!! pulling intake off of a 91Z TPI, what mods can i do?
well my friend's 91z has a leaky intake. so off it must come. what mods can i perform on them? i have heard of porting the plenum as well as the lower base portion? must stay cost effective here, buddy is short on $$$$
is a edelbrock base worth the money? then maybe hand port the upper plenum
tia for any suggestions.
taner
MY car featured:
http://www.bmrfabrication.com/Feature.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.43@ 120.87mph N2O(i shifted 3rd to 6th,DOH!) 1.375 60'
Best mph: 132.95mph w/10.47- yes i hit 4th,lol (Sept 16/01)
oh yeah also an 80 Camaro, an 98 Ram Sport
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
Old Jun 14, 2002 | 06:04 PM
AutoRoc's Avatar
Lightbulb
Tanman,
Is he pulling EVERYTHING off? even the base part of the intake? If so and cash is an issue, I would just port the plenum. The main part is to get rid of the little "Walls" behind the throttle body holes. Those are about 10% of the opening and it helps a lot. As for the rest, I wouod just port match it as good as you can.
Getting into an aftermarket intake and runners can set you back $500-800 depending on what you get. If he has 200-300 to spend, i'd get aftermarket intake runners first(The middle tube parts) . I got my used SLP set for $200 and did the extra port work myself. definately got my 350 to rev to 5500 instead of 5000. Knocked off .3 with just those and increasing the 1-2 shift rpm.
Goodluck man. Keep it simple and you'll be ok. Port the plenum and aftermarket runners if they're in the budget+ port matching.
Denny
Old Jun 14, 2002 | 08:20 PM
Yellowknifer's Avatar
Post
Siamese port the base. It will greatly add to your upper RPM power and u will probably rev to 6000ish. Do a little porting too the heads too if you decide it's not too much trouble...
http://sethirdgen.org/TPIbase.htm
Old Jun 14, 2002 | 10:32 PM
taner's Avatar
Post
Autoroc, what took you so long to reply
the car is now in my garage, tomorrow we tear it apart should be fun. yes the intake is coming off, we recently put on a good waterpump, i think it found a gasket that was just waiting to start leaking
oh well, time to fix it.
Yellowknifer,
thanks for the link that is awesome! it really helps out, you must've read my mind as this is exactly what i was gonna look for i have all the tools i need to get this done! just might pick up some of the smaller bits. i figure we'll need a few days to get this done. then i get his drop top for a day, my choice
MY car featured:
11.36@120.35mph, NA
P.J.
Old Jun 15, 2002 | 12:59 AM
I EAT T/A's Avatar
Post
Most intake mods on a TPI are spendy, so porting is about all you can do for low cash flow.
Brett
'91 Z28 (Black)
TOTALED
Brett's House
MN F-body
Old Jun 15, 2002 | 03:29 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
If you siamese-port the stock intake, you shouldnt need anything else. You can also port the plenum, both the EGR walls behind the throttle body, and enlarge the runner holes on the side.
Dont port the heads while they're on the car. You'll get shavings every where, and thats a very bad thing.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Jun 15, 2002 | 08:03 PM
taner's Avatar
Post
i wish this was my car, i would be spending whatever i had to make the most difference
especially if it could be thrown onto a 350 down the road.
alas it is not, so we are doing the basic stuff.... damnit couldn't find the T40 bit for the intake removal...fuuuuuu*k. oh well have to continue tomorrow.
thanks for all the help!!!
DirtyDaveW
Mar 15, 2015 07:01 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
