Help, I think I broke it....
Old Mar 18, 2004 | 02:42 AM
globalco's Avatar
My trans is acting odd after a close one on Tuesday. Making a left onto a street close to home a WRX decided he wanted to play. It was .. to the wall for about 1/4 mile until I had to make a left. There was no redlining just foot to the floor. I must say even with 155k miles and lifter noise he never got past my door. Not something I like to do or encourage but when you hear a high pitch buzz in your ear what the hay.
Anyway, today I noticed the following problems; the usual punch from gear to gear at normal speeds was replaced with a slow slip into the next speed, entering the freeway there is a definate slip through the gears and an unwanted slip n' slide until OD kicks in. Pretty much there is slippage and a lack of the servo punch that was there before.
Where can I start looking? Servo, accumulators, valve body plungers, or what.
I have a built 700R4
Please help.
Jim
Old Mar 18, 2004 | 03:31 AM
97WS6SCharged's Avatar
I would start by checking your fluid. If you're lucky, it will be just a bit low instead of burnt or missing.
Old Mar 18, 2004 | 04:15 PM
lordmetalz28's Avatar
check you cable tension
truecontr3
Oct 11, 2015 09:30 AM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 24, 2015 11:04 PM
Cbr02
Aug 23, 2015 10:55 PM
