Help! Code 32 & tranny shifting too high of RPM's
Old Feb 8, 2003 | 03:51 PM
copper88iroc's Avatar
Exclamation Help! Code 32 & tranny shifting too high of RPM's
Ive tried everything! Lets see just replaced the CAT, Oxygen sensor, Intake was done, also cleaned out EGR passage and got a Major tuneup. I replaced the Temp sensor and got the fans working properly. The code always throws usually in the morning when its cold. I have another problem! My Tranny is shifting way to high. I justed replaced the passing cable and have tried to adjust it several times but have failed. Please help if you can. Thanks!
Old Feb 8, 2003 | 07:06 PM
aklim's Avatar
When my tranny did that, it was on the way out. Drop the pan and see if you see any filings in it.
Code 32 is EGR and is unessential. I had my chip burner people delete that code. What temp sensor did you change? The engine one or the fan one? It could be that the EGR itself is bad or sticking.
97SSdude
Dec 31, 2014 07:43 PM
Cam's maro
Dec 28, 2014 09:30 AM
mattszm6
Dec 14, 2014 07:09 AM
tds1213
Nov 27, 2014 12:55 PM
newby
Jul 25, 2002 03:22 PM
