help car dies 1st -2nd shift?
Old May 20, 2007 | 04:44 PM
82lt1ta's Avatar
ok i'm having an issue it seems....
my car is a 89 rs with carb'd 305 and a 700r4
when i hammer on it and shift into second just screwing around it dies.... gets to about 1500-2k rpm and starts back up...
any ideas on wtf is goin on?
Old May 20, 2007 | 08:08 PM
confused327's Avatar
it could be a lack of fuel. draining the fuel bowl and running out right at the shift, when it dies it gives the pump time to recover.
Old May 20, 2007 | 11:50 PM
82lt1ta's Avatar
what can i do to help that? bad fuel pump?
Old May 21, 2007 | 07:29 AM
jayman350's Avatar
Is this the stock carb (quadrajet 4bbl)? If so, you might want to give it a rebuild and replace all of the vacuum lines going to and from it. I've rebuilt a couple of Holleys and as long as you take it one step at a time they aren't that bad to do, q-jets are kind of a mystery to me b/c the first thing i did was dump that and put a holley 4bbl on.
It could be a number of things, first ones that pop into my head are
1.) secondaries opening too soon, are they vacuum or mechanically operated?
2.) Accelerator pump cam could be worn down or broken
3.) Vacuum leak, sometimes you will lose a hose off of the base or side of the carb that will cause some funny things to happen
just some ideas to think about
Old May 21, 2007 | 05:15 PM
82lt1ta's Avatar
hey thanks... yea its a stock q-jet.... they suck..
thanks
Old May 21, 2007 | 07:50 PM
if you get on it for the same amount of time in a different gear does it do the same thing?
i would also check all of the vacuum lines for a leak.
Old May 22, 2007 | 10:31 AM
82lt1ta's Avatar
yea it did it to me for the 2nd to 3rd shift...
but i noticed that everything shuts down i mean everything.
gauges bottom and all
Old May 22, 2007 | 07:24 PM
oh, then that means it's probably electrical. do ALL the guages do it? tach, volts, coolant temp, radio?
Old May 22, 2007 | 10:26 PM
82lt1ta's Avatar
yea but it dont have a radio so yea.... but other than that yes....
see i thought some sort of electrical. but not sure what
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
