which heads???
Old Oct 26, 2003 | 12:00 PM
  #31
dj haf's Avatar
aklim, someone told me that since my car is SD (1990), i cant change to a higher # fuel injector.... that i'd have to convert my car over to MAF.... the kid who told me this owns a mustang, and he had to do it, but i just wanted to know if it goes the same with camaros
Old Oct 26, 2003 | 01:10 PM
  #32
shwine617's Avatar
That can't be true, because I have a 90 iroc with speed density and i put 24 lb. injectors in and i don't have any problems, except my idle went up a little bit, but when i get my chip burned that problem will be solved.
Old Oct 26, 2003 | 03:11 PM
  #33
aklim's Avatar
DJ, that kid is on drugs. You can change. Since it is SD, it is not as adaptable but you can with an EPROM burn which you will want anyway since you are doing other mods to it. SD is not as adaptable as MAF but it is a pain to switch.
Old Oct 26, 2003 | 03:48 PM
  #34
dj haf's Avatar
thanks for cleaing that up for me i was thinking that tuning would be the key to everything i do to my car, and when my friend told me about what he had to do to his stang, i was like "i think if i want to run bigger injectors, all i have to do is reprogram the eprom and im set"
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
