Headers?
Old Aug 3, 2003 | 05:11 AM
Kuruption562's Avatar
Headers?
What are good headers for my IROC? how much HP will a good set of headers add? Will it improve my torque?
Old Aug 3, 2003 | 07:25 AM
SharpZ28's Avatar
I have been scratching my head over a set of headers for a while myself. I cant decide on which one ( SLP,hooker,hedman) I hear that for a 350 engine 1 3/4'' diameter tubes are best. You will gain some torque. I would like a set of long tubes for mine, but am still researching on which is best for me.(92 Z28 350 tuned port, 32000 original miles.) Good Luck.
Old Aug 3, 2003 | 10:06 AM
aklim's Avatar
What do you plan for the future, how much money do you have to spend?
Old Aug 3, 2003 | 10:25 AM
SharpZ28's Avatar
My plans are ZZ9 cam, AFR190 heads, Tpis big mouth manifold, 52mm throttle body, and some sort of headers. This will do for now until I can save some more $$$.Hopefully this will get me in the 12s on drag radials.Whatcha think?
Old Aug 3, 2003 | 10:54 AM
cy Z28's Avatar
Long Tubes. You're wasting your time otherwise.
Old Aug 3, 2003 | 10:58 AM
SharpZ28's Avatar
What brand long tubes do you recommend? Being I live on the East coast, I need some that are coated. (92 Z28 350 tuned port)
Old Aug 3, 2003 | 04:43 PM
amc91z's Avatar
anyone have any pics of the exhaust mounted up to some long tubes? I've been wanting a set for my 91 but dont know how the rest of the exhaust will go...
Thanks,
Adam
amc91z@team.camaroz28.com
Old Aug 3, 2003 | 06:37 PM
doug791's Avatar
i like the fact that the hedmans have 3" collectors.
Old Aug 3, 2003 | 06:42 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Hooker Super Comps are probably the best off the shelf headers IMO. If you want to go street low end torque use 1 5/8ths primarys ifyou want some upper RPM power go 1 3/4s. In your case with the plans you mentioned I think I would go with the 3/4"ers
Old Aug 3, 2003 | 06:44 PM
TheGreatJ's Avatar
I run coated Hedman shorties, 1 5/8" tubes into 3" collectors. You don't need 1 3/4" unless you're making more than about 400hp. Longtubes are a little more efficient, but with shorties you can run your exhaust through the stock routing and not sacrifice any ground clearance.
Old Aug 3, 2003 | 06:55 PM
DarthIROC's Avatar
Yeah, and I would think with LTs if you had to pull your tranny it would be a bitch.
Old Aug 3, 2003 | 07:02 PM
aklim's Avatar
SLP 1 5/8 if you are sticking to that list and 1 3/4 if you think you are going further like a 383
Old Aug 3, 2003 | 07:19 PM
CamaroZ28Coupe's Avatar
whats wrong with the edelbrock version of the slp 1 5/8
Old Aug 3, 2003 | 09:29 PM
shwine617's Avatar
I have hooker headers, they work good, the only thing is make sure you get good locking header bolts, I was re tightening the bolts every month.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
