Head Porting
Old May 3, 2004 | 12:01 PM
  #31
Chris`s85Z28's Avatar
Originally posted by Sitting Bull
Wrong.
There is a lot of align honing, overboring, crank turning and block decking that MUST be done for a proper rebuild. Don't waste your time, energy and money on a 305 when you can have a 350 for the same effort.
If the 305 needs rings it is time to change to a 350. Spend $100 or so on a junkyard 350 that needs rebuiding and you will be miles ahead.
That is the bottom line.
Sitting bull is right, But I`m rebuilding my 305 as I found out my rings and brearings are screwed.. so I`m redoin the bottem end too. I polished the crank and I`m getting new brearings and rings, my 305 dosn`t need a over bore so I`m lucky there so all I need to do is hone the cylinders, since everything else is in spec. And hope it all goes well
Theres head gaskets, exshust gaskets and intake gaskets on a head and they all need to be changed. and don`t forget about the valve seals there 2 per valve.
Old May 3, 2004 | 12:05 PM
  #32
aklim's Avatar
If you are getting a JY 350, have the shop do a quick check of the block. I believe they can do a sonic check for core shift. Also make sure it is not already overbored. Maybe you can even go to a machine shop and buy one of their core blocks that they have checked and warranty if it cracks in two.
Old May 3, 2004 | 03:01 PM
  #33
85_305's Avatar
You think that is all that I should be paying for a block? Could it be from a pickup, etc? If I were to do this, (buy a block from a junkyard) how much would I have to spend on parts for it? Like heads, (I already have the carb) exahaust, etc? How much would a 350 performance rebuild kit cost?
I can get these from Jegs, right?
sonic check
Whats that?
core shift
Whats that?
Old May 3, 2004 | 06:16 PM
  #34
Sitting Bull's Avatar
A 350 is a 350 whether it comes from a truck or a car. $100 to $150 is the going price for a rebuildable 350.
You have heads from the 305 you are going to port and polish. No need to change those plans.
Rebuild kits for 350s are actually cheaper than for a 305.
Do the leak down test first and see if the 305 is still good.
Old May 3, 2004 | 08:29 PM
  #35
85_305's Avatar
I can do the leak-down test w/ the engine still assembled?
What about the OTHER parts I will need for the 350.. lol.. that will run me an aditional g-or 2.
Old May 4, 2004 | 12:31 AM
  #36
Yes, it is necessary to have the engine assembled and the starter in position to do a leak down test.
There are no more parts required to assemble a 350 than are needed for a 305.
The problem you face, which has happened to all of us, is that you want everything to work out right away--even though the bank account is slim to non-existent.
Welcome to the club.
Old May 4, 2004 | 01:13 AM
  #37
aklim's Avatar
What is this "bank account" you speak of?
85_305, This will tell you a little more about engine blocks.
Old May 4, 2004 | 02:12 PM
  #38
85_305's Avatar
But the thing is.. I HAVE everything on my 305.. I dont have ANYTHING for a 350..
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
