harmonic damper install question
Old Jul 10, 2005 | 10:59 AM
bad93z's Avatar
I'm installing a tbi motor into an older chevy truck, and my pulleys weren't lined up so I took off my harmonic damper. When I put it back on do I put the key in first? or put it in after the damper is on?
Old Jul 10, 2005 | 12:03 PM
klumb15's Avatar
Re: harmonic damper install question
the inside key has to be in, because that is what lines up your balancer....but the front key doesn't even come in contact with the balancer if I remember right...but when everything is said and done, they both should be in there...
Old Jul 10, 2005 | 03:05 PM
TheGreatJ's Avatar
Put the key in the keyway first, then slide the balancer on over it. That's the only way it will go together.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
