GUYS I NEED HELP ASAP.........
Old Jul 27, 2002 | 10:38 PM
  #16
phoenix916's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Rumblin91:
A 180 degree thermostat would probably suit the car better. Sometimes w/ the 160 degree thermostat the coolant doesn't stay in the radiator long enough to cool off.</font>
I agree 180 should be good. Im not sure on the 2 or 3 plugs into the computer. I swapped in an lt1 and brain and took out my old one. I was just looking at what I have left under the dash and I believe there is only 2 plugs. My car was tbi and maybe there is an extra plug for tpi. Also, was anybody elses brain velcroed in?
Old Jul 28, 2002 | 02:18 AM
  #17
RedIrocZ-28's Avatar
Post
A 160 thermostat is fine. Whoever tells you different doesn't know the difference. Running too cold? No... the reason some people say that a 160* stat runs too cold is because the calibrations on the EPROM dictate that at about 110-120* F the car goes into closed loop. And with a 160* stat in the winter, you may not ever reach closed loop. 160* stats kick ***. If you want to run 190-200 degrees then run a 180 stat. Its up to you if you want to gain horsepower or lose it. My car runs between 160-180. Anything over 200 or so you can literally feel the loss of power. Colder is better unless you go too cold and start running in open loop all the time. But as I said before, you aren't too cold at 160*.
Old Jul 28, 2002 | 05:02 PM
  #18
Rumblin91's Avatar
Post
Heat makes power...my car feels stronger around 190 than it does at 160. Only reason the car runs better cold is because of the colder air and fuel charge. Cold air induction and you wouldn't notice any difference running that cold.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
