Gm "fastburn" Heads
Old Mar 25, 2003 | 07:54 PM
99huggerorangeZ's Avatar
Question Gm "fastburn" Heads
i am building a 377 stroker(350 block 4" bore) and i am wondering if these heads are any good and if they would be a good choice to run
Old Mar 25, 2003 | 07:58 PM
IROC350's Avatar
re
if you have the money to spend i believe the GM Fastburn III's are the best heads on the market. they have an excellent flow rate and you can get them ported for $1000 more
Old Mar 25, 2003 | 08:05 PM
jzajac1's Avatar
I have a Fastburn 385 which comes with Fastburn heads. I can't compare them to a different set but I did add the Hotcam kit which boosted it to 430 hp. My research indicates that the heads will support over 500 hp. What other additions are you planning to add to the 377. Is this going to be a replacement engine for the 383 you have in your signature? If so, you probably won't make more horsepower then what you have now unless you really get radical.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
