getting car out of storage
there were tons of postsabout what to do to the car before it goes away for winter. i did everything i could for storage, changed atf, rear gear lube, full tank, take out battery, gasline storage stuff, bounty sheets etc...
so what do i do before i crank it up? ive heard dumping in some desiel fuel into the cylinders before you start it is good, but how much do i put in? do i fill it? and how far can i drive with the desiel in the oil, as the car is on a farm in the middle of nowhere.
I wouldn't put diesel fuel in the car.
If you are worried, I would make sure the battery is good, pull off the wire from the coil to the dist and crank it a bit to get the oil flowing and start it up. Then warm it up for a bit. DON'T BEAT ON IT for a bit.
everybody told me not to but i start my iroc every week during the winter to keep it lubed , they say its the worst thing to do but for 2 years i never had any problems. i just change all the fluids in the spring
I'm thinking that when its sitting for that long all the oil drains down into the pan, so instead of starting it like that once a year, your doing it every week. Where as if you drive it every day, there is probably still some oil throughout the motor when you go out to start it in the morning.
got it out today, drove it around
forgot how much i liked it. feels like drving a ping pong ball as apposed to a brick with my towncar
anywho i did take offf the coil plug and cranked it over before firing it up. good idea. it was raining pretty good out so i didnt want to spend much time doing it.
NewsBot
Dec 3, 2014 12:30 PM
owen66
Nov 30, 2014 04:21 PM
