Gears
Old Jan 1, 2004 | 10:40 PM
Kwiksilverz28's Avatar
Gears
I just bought a 88 GTA to play with and drag it, and it has the 9 bolt with 3.23 gears. How much of a difference would going through the hassle of finding gears and a shop to do the swap to go to 3.73's, or is it not that big of a deal? I don't think I would do 4.11's or whatever the 9 bolt equivalent would be, just to keep it more streetable. Or should I go 4.11's? It does have a 700R4, so overdrive should help... Thanks!
Old Jan 1, 2004 | 10:48 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Your 9-bolt will have 3.27 gears. 3.23 is the 10-bolt ratio. You can get 3.45 gears or 3.70 or 3.73 gears from http://www.diffsolutions.com/ or another rear end specialist. With a 700R4 you definitely do not want to go higher than 3.7x gears.
Old Jan 1, 2004 | 10:54 PM
Sorry, it is late.
So, is it worth the effort to go from 3.27's (the tag is on the rear, so I am sure..) to 3.70/3.73's?
Thanks for the quick reply!
Old Jan 1, 2004 | 11:01 PM
Kevin91Z's Avatar
On a stock engine, probably not, but once you've upgraded the intake to where it flows at higher RPMs, then you'll want better gears.
Old Jan 1, 2004 | 11:33 PM
AutoRoc's Avatar
I'd stick with the 3.27's for now and see how it does. A better torque converter would be a more worthwhile start probably. Better breathing and a 100 shot of nitrous makes the game really fun. Don't forget sticky tires or you won't be passing anyone until the end of the track.
Old Jan 1, 2004 | 11:54 PM
That really sounds like more of a plan. I figure somewhere around a 2500 stall convertor and headers/exhaust are the first 2 mods......
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
