Just to explain the instuction for installing new Gears & Limited Slip in a rear would take to long. So the short of it is if you must know it is NOT a normal DIY job.
It took a mechanic 7 hours to do it because I was using Richmond Gears and they require different specs. Also he had to take the gears out 4 times just to get the wear pattern perfect.
