Headers?
Old May 7, 2003 | 06:24 PM
SharpZ28's Avatar
Headers?
What is everyone's favorite headers for the L98 engine? I am thinking about either SLP 1 3/4 inch or Edelbrock nickel plated. Also, how much skin do you have to lose to install them? THANKS!
Old May 7, 2003 | 06:33 PM
IROC350's Avatar
i myself have the hedman shorty's. it depends on what you want outta the car. shorty's will wake it up a lot!! i'm not sure if there is a major hp difference between them and the LT's
Old May 7, 2003 | 07:12 PM
SharpZ28's Avatar
Because the L98 is a torque engine, I guess that's what I am looking to gain. I have removed both cats and added flowmaster muffler. The shorties would probably be easier to install compared to the long tubes. Thanks for the input.
Old May 7, 2003 | 07:58 PM
TheGreatJ's Avatar
Longtubes make better torque, and slightly better HP. Installing them is a pain though, and you have to get creative with the Y-pipe if you don't wanna spend a ton of money on one. I personally am going to use shorties, because longtubes won't clear the T-56 clutch hydros (or so I've been told.)
SLP makes great headers, and so does Hooker. Hedman's are pretty damn good, but not quite as good as Hooker or SLP. Edelbrock I hear mixed reviews about...some like them some don't. I personally will get either Hedman or Hooker.
Old May 7, 2003 | 08:54 PM
IROC350's Avatar
LT's are better for top end power. and i spent 150 on my Y-pipe with the shorty's.
Old May 8, 2003 | 12:09 AM
aklim's Avatar
It depends on what you plan to do. I hated the Edelbrock TES. I have SLP 1 3/4 but if you are not doing serious mods, I'd go 1 5/8
Old May 8, 2003 | 07:04 AM
SharpZ28's Avatar
I am leaning towards the SLP 1 3/4 headers. I am planning on more aggressive mods in the future. Does anyone know from experience what is the limits for engine mods, before computer recalibration is needed? I have the speed density system on my 92 Z28.
Old May 8, 2003 | 07:23 AM
irocz8957's Avatar
slp will give you the most noticable gains!
Old May 8, 2003 | 08:29 AM
aklim's Avatar
If you are doing headers you shoud be fine. However, just from personal experience, the EPROM in your car is not the greatest. I stuck the Accel Superram on my car and noticed a great difference. Next came headers and there was even more difference. However the car was not really running at it's best. I took it down to Lingenfelter and he really woke the car up with an EPROM change. Took a while because he would drive the car, burn the eprom and do it a couple of times. He also had to have monitering equipment hooked up. Since I could not drive the car there the last time I had stuff done, he recommended www.fasterproms.com to fix the eprom. They would burn you a chip to your specs, have you install it and take readings, do it a couple of times till it is nuts on then charge you $350. In future, if you want to repeat the procedure, it is $150
Old May 8, 2003 | 10:39 AM
IROC350's Avatar
don't forget, if i'm thinking right, you will need to make a new hole in the header for the o2 sensor!
Old May 8, 2003 | 08:53 PM
aklim's Avatar
AFAIK, on the SLP ones and the Edelbrock and Accel (not made anymore), They all have a O2 sensor bung.
Old May 10, 2003 | 07:06 AM
SharpZ28's Avatar
Thanks for the replies, I would like to get the car in the 12's. I ran the car for the first time last thur night, it went 14.34 @ 95. I wanted a base run before I start bolting on things. I am not going to get too radical with mods, I am thinking of Vortec heads and 150 shot nitrous kit.
Old May 10, 2003 | 11:10 PM
91RS5speed's Avatar
I would say SLP cause there stainless steal and you can get them coated. That way they will last a long time. Also they are the only company with 1 3/4 inch primaries.
Old May 11, 2003 | 12:57 AM
Shaun 90 Iroc's Avatar
Yes.. about to do Vortec 350 swap into mine here in a couple weeks if you want to know the results..
www.madirocz.com
Old May 11, 2003 | 05:45 PM
zulater91's Avatar
with long tube headders would i need to move the knock sensor
