gauge cluster
Old Feb 5, 2003 | 05:05 PM
cowlcamaro's Avatar
Question gauge cluster
I need to know if all 82-92 camaro gauge cluster have the same plugs. Because I am looking at one on ebay but its a different gauge setup then mine. I need to know A.S.A.P!!!!
tHANKS
Old Feb 5, 2003 | 06:50 PM
MRZ28HO's Avatar
Exclamation
The camaro guages are different.
'82-'89 have the dual round speedo and tach gauges
'90-'92 have the "half moon" style.
No, you can not mix the early ('82-'89) and late ('90-'92) guage cluster with the opposite dash, they won't interchange without a full guage cluster swap.
Old Feb 6, 2003 | 01:01 PM
guitarman's Avatar
What does a cluster consist of? My speedometer is failing, the needle jumps all over. I took it to the local chevy dealer and they put a new buffer in it but that didnt fix the problem... how much would a new cluster cost for my 92 RS Camaro?
-Matt
Old Feb 7, 2003 | 07:41 PM
Scotty C's Avatar
I have an instrument cluster available from my '92 RS. It is in perfect condition and shows 48,979 miles. All gauges work properly. Let me know if you are interested.
I also have an instrument cluster from a '91 Z28. It has the 145mph speedo and higher redline tach. It would be a direct replacement for your current cluster.
Old Feb 7, 2003 | 08:29 PM
ZZ430RS's Avatar
Mine went out about 6 months ago but it just quit working all at once, I got a price quote of $150.00 to have it repaired here... http://www.instrumentclusters.com
Then called a few local wrecking yards and got prices of anywhere from $50-$75 for a used one, I was in a hurry so I just got a used one for $55 at the closest yard. I still want to fix the old one some day.
Old Apr 11, 2021 | 04:23 PM
Kprice1014's Avatar
Re: gauge cluster
do you still have a gauge cluster available?
Old Apr 11, 2021 | 06:14 PM
Re: gauge cluster
“Scotty C” hasn’t signed into this site for more than 17 years.
194bird
Mar 23, 2006 01:32 AM
ticketgetter2
Parts Wanted
Mar 5, 2005 05:24 PM
squinn
Parts Wanted
Jan 29, 2004 11:40 PM
Z28James
Oct 18, 2003 02:13 PM
brxndxn
Mar 31, 2003 02:18 AM
