Gas Tank
Old Apr 25, 2005 | 10:14 PM
69gto96z's Avatar
Gas Tank
Just seein if anybody knew if the gas tank out of a 93-97 Z-28 would fit a third gen firebird. If anyone knows please let me know.
Old Apr 26, 2005 | 07:25 AM
Dave89IROC's Avatar
Re: Gas Tank
yes, with some mods needed(shorten filler neck and the fuel lines[different fittings])
Old Apr 26, 2005 | 11:35 AM
Drkhrse89's Avatar
Re: Gas Tank
Since the LS1 tank has a rubber filler neck I have heard a lot of people going with that one as well.
Old Apr 26, 2005 | 04:09 PM
Dave89IROC's Avatar
Re: Gas Tank
one really nice thing about the LS1 tank, other than being plastis, it has some major baffling inside
Old Apr 27, 2005 | 12:36 PM
Drkhrse89's Avatar
Re: Gas Tank
Oh really I did not know that. I have been keeping my eye open for a 1LE third gen tank because of that exact reason. I am going to now have to do some looking into the tank swap for later on.
Old Apr 27, 2005 | 10:58 PM
Red89GTA's Avatar
Re: Gas Tank
99+ are plastic, are lighter and have a larger capacity. I believe that you need to shorten the filler hose like mentioned earlier.
Old Apr 28, 2005 | 01:03 PM
respectirocz's Avatar
Re: Gas Tank
how much would a 4th gen gas tank cost?
how much lighter is it
how difficult is it to shorten the filler neck?
Old Apr 28, 2005 | 05:20 PM
RedIrocZ-28's Avatar
Re: Gas Tank
how much would a 4th gen gas tank cost?: Less than $100 AFAIK
how much lighter is it: Not much at all, a few pounds is all really...I think the figure was 6lbs??
how difficult is it to shorten the filler neck?: Apparently just a razor knife.
However, this is all putting the cart before the horse. You also need to modify the sending unit to get it to work with a 3rd gen. You need to puncture part of it, not sure which, to enable the return line to dump the fuel back into the tank. Also, provisions need to be made for the charcoal cannister.
Go to www.thirdgen.org and search for "LS1 gas tank in 3rd gen" and see what you getr.
Nayr
Mar 3, 2023 08:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
