Fuses
Old Feb 2, 2003 | 07:30 PM
83z28blue's Avatar
Fuses
I need some help here. I don't have a fuse panel, so there's no diagram for what fuses to use. I was wondering if I could get the info on all the fuses so that I know what ones to replace and check.(some of them are empty, and they were missing when I bought the car 1 week ago, so cant check that way). Thanks
Old Feb 3, 2003 | 01:06 AM
83z28blue's Avatar
Exclamation
Come on guys, this is an easy one. It's a 1983 Chevy Camaro Z28, I see plenty of you with the same car. I just need the fuse panel map, you can take a picture, or write down each one. It's the thing on the back of the panel, it should be color coded or/and have the type of fuse need for that slot(10amp, 20amp, etc). Also if you can give info on which ones to bother with. This would be greatly appreciated Thanks
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
RUNMYTA
Jul 15, 2015 07:50 PM
