fuel pressure regulator
Old Apr 30, 2003 | 01:27 PM
irocz8957's Avatar
how big of a dif. did they make on your car (if you have one)
Old Apr 30, 2003 | 02:11 PM
aklim's Avatar
None, I had one and set it to stock pressure. I bought it because it was cheaper than the GM one at the time I was replacing it. Where I needed more fuel, it was done with changes to the EPROM. As far as I am concerned, the AFPR is just a crude EPROM fix. It changes the fuel delivery throughout the band not just at the spots you need.
Old May 1, 2003 | 07:53 AM
irocz8957's Avatar
ttt
Old May 1, 2003 | 09:27 AM
Jim85IROC's Avatar
I pretty much agree, but if you don't burn your own PROMs, an AFPR can be a helpful tool.
Old May 2, 2003 | 01:34 PM
aklim's Avatar
For $350 for the first chip and $150 for each mod from www.fasterproms.com or anyone else who does a truely custom chip, you can get better performance. Why waste time with a AFPR which all you are doing is enriching the entire curve whether it needs it or not? If you increase the pressure to little, the ECM will just shorten the fuel pulse width to compensate. You would need to bring it outside the range of compensation which would make the WOT great but the rest of it too rich. In that case, why bother with EFI? Why not go carb where you could stick on a set of larger jets when you need WOT and smaller jets when you just do cruising? Just have a carb for all occasions.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
