fuel pressure problems...
Old Apr 2, 2006 | 08:51 PM
z28_theantirice's Avatar
Well a buddy of my recently aquired a 1986 Iroc Z for free from his aunt. The car has been sitting for 6 years, and we are in the process of getting it back on its feet right now. Surprisingly the car starts and idles fine. But dosent like to turn over 2k, first thing we checked was the fuel pressure and sure enough with the key on it is at barly 20psi. Under throttle it is all over the place. So far we have changed the fuel filter, so whats next the fuel pressure regulator?
Also what are the stock specs for fuel pressure with the key on, and with the car running?
Old Apr 2, 2006 | 09:25 PM
Kwiksilverz28's Avatar
Re: fuel pressure problems...
You need to post the induction system of the car!
Old Apr 2, 2006 | 09:27 PM
sorry it is a TPI car
Old Apr 2, 2006 | 09:32 PM
These are TPI numbers at the bottom...
Old Apr 2, 2006 | 11:18 PM
89Vert's Avatar
20 psi is not enough
Old Apr 3, 2006 | 10:24 AM
I know its probably the pump, but is there anyway I can be 100% sure its the pump and not the fuel pressure regulator?
Old Apr 4, 2006 | 07:33 AM
Yes. Look at the chart I gave you. It lists a pump pressure that is determined with the return line clamped. Of the 2 going to the motor, it is the smaller. Worst case, if you clamp it and get 0 pressure, it is the other line.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
