Fuel filter change - mess
Old Sep 20, 2003 | 11:34 AM
  #16
Pro
Guest
Posts: n/a
Originally posted by NastyCamaro
According to Haynes
step
1. Remove the fuel punp fues located in the fues block . Located inside the passenger compartment under the left side of the dash .
2.Start it , then let it run untill the lack of fuel causes it to stop.
3.Engage the starter for about 3 seconds to make sure the pressure is relieved .
4.Turn the key off and disconect the Negative battery terminal.
5. After serviceing the fuel system , reinstall the fuel pump fuse.
...there is a fuel pump fuse in the cluster .... Top level ...second over from the left labelled " f pump"
and I have twisted my fuel lined before ..... amke sure you don't ....because gas REALLY burns . and I had to jerry rig it so I can drive it ....untill I can get new lines done
Interesting. My book (which I threw away yesterday) says the fuse is on the right side of the dash .... I was like whaaattt.
But even in the fuse box there is no fuse for the fuel pump.
Old Sep 20, 2003 | 11:53 AM
  #17
NastyCamaro's Avatar
I asure there IS a fuse there for it ....its a 20 amp one
I have a TPI car ...... maybe your is different ....but I doubt it
Old Sep 20, 2003 | 04:32 PM
  #18
IROC-T's Avatar
If you have a fuel pressure gauge with a hose ,like a hypertech,just take the gauge off the hose and place the end in a coffee can and attach the other end to the shrader valve. Quick and easy.
T.
Old Sep 20, 2003 | 08:54 PM
  #19
Camarodiehard's Avatar
My saga ends here...
(I read both Hanes and Chiltons, neither was complete in explanations and steps)
Hi! Good news, I changed my fuel filter . Here's what I did:
1. Jackstanded car , front and back, driver's side
2. Loosened gas cap, let it vent
3. Took out fuel pump fuses, 2 (FP)
4. Started motor, let it ran 2-3 minutes (inj.#1 running on oil pressure mecanism, fail-safe...)
5. Pulled out fuse in black sleeve facing battery and pinned clearly near fender
6. Killed motor instantly
7. Fuel pressure was then releived to the fullest
8. Took adjustable wrench (wescot) and 16 mm wrench key
9. Took 10 mm socket, socket driver and 3'' extension
10. Took 2 small pans (plastic)
11. Put on latex gloves, cotton head cap and goggles
12. Went under
13. Wescot on fixed nut welded to fuel filter (FF)
14. Wrench key on moveable nut (MN) centered on fuel line (O-Rings?? sorry , not a pro...)
15. Loosened MN, motor side, by counter forcing wescot and wrench key (pretty easy, no rust, lucky...)
16. Minimal fuel spill
17. Same loosening action on MN , tank side
18. Again , minimal fuel spill, it even diminished after about 20 seconds!
19. Loosened small bolt , 10mm, on metal clamp that holds the filter in place (easy, again no rust, lucky....)
20. Made quick moves to swap new one in proper flow direction , like indicated on Fram filter...
21. Old one : AC Delco part # GF-481. Maybe the original FF, who knows...?!
22. Tightened reasonably MN (O-rings ?) in place, nice and clean
23. Smiled inside while wiping underside
24. Tightened bolt on metal clamp
25. Job done
26. Pulled myself up from under and did indian victory dance with neighbor...
27. Went for a ride, now pulls better, quicker and smoother...no kidding
Am very grateful for everybody's help and counsel : ), thanks
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
Jul 4, 2005 05:00 PM
