Fan switch delete?
Old Mar 8, 2005 | 06:24 PM
ZDADDY92's Avatar
Question Fan switch delete?
Anyone out there removed the coolant fan switch and just hardwired their fans? I know you can hardwire them, but I am unsure as to if not plugging in the fan switch will throw a code or cause the computer to runn funny-Thanks in advance-
Old Mar 8, 2005 | 07:24 PM
MdFormula350's Avatar
Re: Fan switch delete?
too much trouble and work, just use what u have wiring and all, and just ground the relays with a switch to turno them on or off when the car is on.
alot of info on www.thirdgen.org
about wiring fans to switched.
Old Mar 8, 2005 | 11:46 PM
92RS305#2's Avatar
third gen cars have two things that turn on the cooling fan, the cooling fan switch located on the passenger side of the car and the a/c system. i cut off my cooling fan switch wire and was just gonna hook it up to a toggle and ground it to turn it on but its too much of a pain IMO. so now until i get a fan that meets my temp range needs i just use the max a/c on low to turn on the fans if i get too hot, i did the a/c delete so it doesn't affect me any. get a switch that turns on at a lower temp range so you don't have to worry about all that turn on/off junk.
Jeff'SS
Jun 1, 2015 06:21 AM
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
