Engine swap
Old Mar 28, 2003 | 03:55 PM
danno91's Avatar
Engine swap
I just bought a 350 TPI from a 91 Z, and I am planning on putting it in my 91 RS that came with the 305 TBI. I also got the ECM and wiring harness. I was just wondering if there was anything I should be on the lookout for before I start this project? For example, could I use my wiring harness or do I need the harness for the 350.
I also have T5 in my car and I heard that they are only rated for up to 300ft/lbs. The 91 L89 is rated @ 345ft/lbs. I don't plan on racing but maybe the odd little adrenalin rush! Will my tranny last?
Old Mar 28, 2003 | 06:58 PM
StealthElephant's Avatar
If your not popping the clutch at 4500k and abusing it you should be fine for a while.
Old Mar 29, 2003 | 02:20 PM
TheGreatJ's Avatar
"For a while" being the operative phrase. The T-5 will hold if you don't thrash it but sooner or later it's gonna give in to the extra torque. Stick the 350 in and enjoy it, but start saving for a new tranny.
Old Mar 29, 2003 | 04:05 PM
Chris Ja's Avatar
Eternal Member
Smile
if you are using the TPI then you will have to change the harness and ECM. If you are going to stay with TBI then your harness will work fine.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
