Engine Struggles when started
Old Mar 21, 2003 | 11:08 AM
camarocruzin's Avatar
Alright the car was warm, just been driven gently for about 15 minutes, parked for about 25-30. I came back out to the car started it, it didn't do it's normal go up to about 1200 rpm and idle down. instead it only went to about 500 the bogged and dropped to about 350, sounded like it would stall, but it saved itself, back up to about 500 then back to 350.....you get the point i gave it gas but the instant it went back to idle same thing. I finally ave up and just drove the car. Parked it at work, popped the hood and the A/C lines were cold and they had condensation all over them???? I had my defrosters on with the temp all the way to hot. I researched on this board and found that the A/C will run with the defrosters to eliminate humidity...is this true? Also what would explain the bad idle? It's got new plugs, wire, cap, rotor, and coil. I think it needs a fuel filter and im gonna do that with this next oil change. Was the struggline just because i started the car with the defrosters on and it strained the engine??? It's an '89 IROC with the 350
Josh
Old Mar 21, 2003 | 12:29 PM
CODY BEHNKE's Avatar
Could be a couple of things, the computer would correct the idle to make up for the A/C being on. Have you ever cleaned or replaced the EGR or Idle Air Motor?
Old Mar 21, 2003 | 04:18 PM
THanks for the reply
No they haven't been as far as i know, could you direct me to some articles, or explain what that involves?
Thanks Josh
Old Mar 27, 2003 | 03:47 PM
DeanZ28's Avatar
plugs
sounds like my 92 z28, the rough startup. I pulled my spark plugs to check them, they were black. No problems since.
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
guionM
28
Aug 19, 2002 05:02 PM
