engine mount swap...
Old Aug 5, 2003 | 09:26 PM
doug791's Avatar
In an effort to isolate my vibration problem im replacing my stock sagging motor mounts with some poly ones (picked up a pair slightly used for 25 bucks canadian yipeeee). Do i need any special tools to do the job? Is there anything i should know about interms of problems i might run into. Any tips from the seasoned veterans because ive never done this b4.
Old Aug 5, 2003 | 09:46 PM
Rustsucks's Avatar
To get the motor up high enough you would want to use a piece of wood under a jack. Put this under the balancer and this should get your motor up high enough to change them. They are a pain though and on my Camaro when I changed mine there were nuts that liked to come loose and roll down in the crossmember. Im not sure though and could be wrong it was five years ago when I did it. Shouldnt be to hard though. Good luck!
Old Aug 6, 2003 | 04:55 PM
Z28SORR's Avatar
Watch the distributor when you jack up the motor.
Old Aug 13, 2003 | 02:09 AM
m0nk's Avatar
I changed the motor mounts on my 87 for a v6-v8 conversion. DEFINATLY make sure you dont drop the bolts down in the crossmember, if you do, make sure you have a 9 year old little brother to stick his lil hands all the way in the crossmember to pull them out when you do.
Old Aug 14, 2003 | 01:57 AM
10sallday85Z28's Avatar
make sure you tske off that distibutor cap. It could hit the firewall and crack. U dont want to find that out the hard way
Parts Wanted
Mar 17, 2015 11:24 PM
Jason Short
Jan 19, 2015 06:34 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
