engine codes 22 & 32
Old Dec 23, 2007 | 01:34 PM
98Zragtop's Avatar
My 91 Camaro with a 305 engine with 126,000 miles has started to change the engine rpm's while cold. I checked the trouble codes and it came up with codes 22 & 32. Has anyone had to fix either of these problems before? This is the first time that I have had a problem with the throttle position sensor or the egr valve. Any advice or suggestions about these problems is greatly appreciated.
Thanks for your help.
Shoup
Old Dec 25, 2007 | 10:14 PM
quickchicken's Avatar
code 22: low voltage at throttle postion sensor or fuel cutoff relaycircutopen orshorted to ground
code 32: fault in barometric pressure sensor circut or fault in exaust recirculation valve diagnostic switch or fault in electronic vacuum regulator valve.
id say your 22 is a bad or going bad TPS. and your 32 is a bad EGR or MAP sesor.
Jul 4, 2005 05:00 PM
centric
Aug 15, 2002 09:04 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
jrp4uc
Jun 19, 2002 06:20 PM
