Drum Brake to Disc Brake Rear Q's
Old Feb 28, 2004 | 11:38 AM
slayer6x6's Avatar
Im getting a good deal on a disc brake rear from my buddys 86 T/A that he wrecked. If mine is a drum brake rear is there anything elese i would need to change, or will it be a direct swap?
Old Feb 28, 2004 | 02:43 PM
Stephen 87 IROC's Avatar
The housing itself is a direct bolt in. The park brake cables might be different. You should also grab the proportioning (combination) valve. Grabbing the master cylinder wouldn't hurt either.
Old Feb 28, 2004 | 08:00 PM
aklim's Avatar
Check the rotors to make sure it is within spec and change the pads.
Victor Lamb
Aug 26, 2017 02:52 PM
carguy0119
Apr 11, 2016 11:11 PM
dale3in98
Feb 14, 2015 12:18 PM
Cam's maro
Jan 8, 2015 05:01 AM
Jazsun
Dec 29, 2014 12:14 PM
