drivetrain question
Old Feb 10, 2004 | 01:02 AM
dave99gst's Avatar
drivetrain question
i have a 83 firebird that was orig 6 cyl, still have the orig rear in it. can i use the v8 driveshaft from a v8 with a turbo 350, or do i need to swith the rear. i am eventually gonna swap it but i want to get the car up and running for now.
Old Feb 10, 2004 | 01:26 AM
kevin 2.8's Avatar
the rear should be fine. it will be a 2:73 or a 3:08 ill be corrected shortly if im wrong
as long as the drive shaft was from a v8 and the tranny is v8 it should work
and youll get good milage
Old Feb 10, 2004 | 06:18 PM
my96awd's Avatar
so aslong as i get a 82 driveshaft because of the turbo 350 it should still work. ive read that the rears are about the same in v8 and v6 somewhere, other then the gear and the one wheel peal. is that true? if it is ill just get a spool and a gear and be all good right. the car is a weekend warrior. basicly would just get drove to the street race and back.
Old Feb 10, 2004 | 06:23 PM
Black6SpdTA's Avatar
Correct me if I'm wrong but a TH350 is shorter than the 700R4, thus a longer driveshaft. Any stock F-Body '82+ driveshaft will work. If you do need a stock d/s, I've got a stock steel one I'll give you for $5+shipping.
CScheip92@hotmail.com
-Corey
Old Feb 10, 2004 | 06:54 PM
my96awd's Avatar
82 83 had the 200 not 700. 83 had the 700
Old Feb 10, 2004 | 07:34 PM
Good call, but IIRC, the 200/700 are the same length.
Old Feb 11, 2004 | 10:27 PM
my96awd's Avatar
i read that the 200 was shorter then the 700 and thats why you need a 82 83 driveshaft for a short tail turbo 350 swap.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
importkiller94
Jan 17, 2015 09:03 PM
cmdeshon
Jan 4, 2015 11:15 AM
Camaro90RS
Jul 23, 2002 07:57 AM
