TPI intake w/ vortec heads??
Old Feb 3, 2004 | 07:41 AM
DooSPX's Avatar
I have a friend who has a 5.7 350 TPI 87 Trans Am... and he is wanting to rebuild the motor and run vortec heads, can you run the stock TPI with vortec heads or will they not bolt up? Please any help will be appreciate it.
Old Feb 3, 2004 | 08:15 AM
Dirt Reynolds's Avatar
He will need this lower intake manifold from Scoggin-Dickey to use his Vortec heads with the TPI setup.
Old Feb 3, 2004 | 10:39 AM
aklim's Avatar
You will need the intake mentioned or it will not work. Go with a set of used aluminum heads that will better serve him in the future. For instance, I have AFR 190 heads and I am musing with changing it to the HSR. I can do that whenever I want because I am not saddled with that intake. Say something better comes down later. He might not be able to use it.
Old Feb 3, 2004 | 01:45 PM
kevin 2.8's Avatar
those runners look wicked
wish i had an 8
Old Feb 3, 2004 | 03:23 PM
stanghunter211's Avatar
Doesanyoe know if its a pain to fab that EGR tube into the headers or what??? Sounds like doing this custom thing might cause some leaks and what not? I was planning this setup and never knew this was a factor.
Will
Old Feb 7, 2004 | 01:23 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
No its not too difficult. This setup is on my car with Corvette heads, but its the same as my dad's setup with Vortec heads:
http://para.noid.org/~thresher/image...1/DCP_0162.JPG
Old Feb 7, 2004 | 10:33 PM
What kind of headers are those? Did they come with that little flange? I need details Thanks bro
Will
Old Feb 8, 2004 | 11:55 AM
1fastformula's Avatar
Talking
Definitely need the base plate and EGR kit (if you keep the EGR).....I have the Crate HO 350 w/vortec and the TPI does prety good with it.
Later
Old Feb 8, 2004 | 04:32 PM
YeahI am definitielykeeping the EGR... Just wanna see what I am getting myself into with this fabrication
Will
Old Feb 8, 2004 | 04:38 PM
Will
Scoggin Dickey makes an EGR kit (the one I have) for about 160 dollars.....
Later
Old Feb 11, 2004 | 10:52 PM
Kevin91Z's Avatar
Will
Those are "customized" SLP 1 3/4" headers.
dawg irocz
Feb 10, 2015 10:33 AM
MadMav
Feb 6, 2015 11:02 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
95chwagon
Jan 13, 2015 09:19 PM
