Drag co efficiency
Old Jul 16, 2004 | 12:48 PM
Omega_Red's Avatar
Drag co efficiency
Does anyone knows what is the Drag
co efficiency for 3rd gen Camaro?
Also what is an average weight of a 1988 Camaro just the body and not engine
Thanks!
Old Jul 16, 2004 | 01:18 PM
87DJP2001's Avatar
If I remember correcty the Coefficient of Drag on 3rd Gen Car was about .30/.32. Never seen a cars weight asked that way, just subtract about 500 lbs from the total weight for a estimate.
Old Jul 16, 2004 | 02:45 PM
Omega_Red's Avatar
That low? Is it possible?
Old Jul 16, 2004 | 07:42 PM
Stephen 87 IROC's Avatar
I use 0.33 with Drag2000. Firebirds might be 0.31
Old Jul 17, 2004 | 03:34 AM
Zepher's Avatar
Firebirds range from .299-.32.
Camaros should be higher than .32 since you have the exposed headlights and air intake.
Old Jul 17, 2004 | 06:26 PM
FruityOne's Avatar
Firebirds
.299 - 82-83 T/A's without GFX, and all firebirds without GFX (think KITT)
.320 - 84-90 Trans Am's
.340 - Headlights up....
.330 - 91/92 All models
_________________
Camaros
.340 - All years.....
All Firebirds and Camaro's have a frontal square area of 22ft^2
A smallblock chevy dressed with all accesories is about 550lb/s from what I understand.
The T-5 transmission is about 120lbs I think. However the clutch assembly and hydrolics adds another 20lbs I believe.
Typical 700r4 is about 170lbs with fluids and torque converter. I can lift a loaded 700r4 with mild difficulty to move it around. Don't ask me to carry it to the neighboors though!
Old Jul 17, 2004 | 07:03 PM
CamaroZ28Coupe's Avatar
wow thats cool info, is there a site that i can check out that you got it from? thankyou
Old Jul 17, 2004 | 08:09 PM
FruityOne's Avatar
I didn't get that info any one place. Its what I've gathered from GM's brochures, as well as other media.
Old Jul 17, 2004 | 10:19 PM
Omega_Red's Avatar
Wow awesome info, thank you!!!
Old Jul 18, 2004 | 10:49 AM
87DJP2001's Avatar
Still good number vs Late model cars.
Old Jul 18, 2004 | 12:24 PM
trackbird's Avatar
I think the T5 is 98 lbs. That is the number I got when I was doing my T5 swap in a 3rd gen (before T56's were readily available). But, either number is probably close enough.
Old Jul 18, 2004 | 08:32 PM
Zepher's Avatar
Re: Drag co efficiency
Dry T5 itself is 85lbs. I shipped my old one to a guy down south.
Old Jul 18, 2004 | 10:57 PM
IZ28's Avatar
Originally Posted by Gunny Highway
How do those numbers stack up with other sports cars, and new cars of today?
Still better than most.
Old Jul 18, 2004 | 11:36 PM
trackbird's Avatar
I must have over-crated mine. I think my shipping weight was 104 lbs (I sold it to a guy in NY).
That is quite possible, I was sure that 120 was too high, but 85 may be correct, I may be a little off.
Old Jul 18, 2004 | 11:40 PM
FruityOne's Avatar
Thats why I added a qualifier to my post. I wasn't sure because I really haven't done to much work with a T-5 transmission. Most of my expereince has been with 700r4 trannies.
If you say they are about 100lbs then I agree with your statement.
