If I remember correcty the Coefficient of Drag on 3rd Gen Car was about .30/.32. Never seen a cars weight asked that way, just subtract about 500 lbs from the total weight for a estimate.
I use 0.33 with Drag2000. Firebirds might be 0.31
Firebirds
.299 - 82-83 T/A's without GFX, and all firebirds without GFX (think KITT)
.320 - 84-90 Trans Am's
.340 - Headlights up....
.330 - 91/92 All models
_________________
Camaros
.340 - All years.....
All Firebirds and Camaro's have a frontal square area of 22ft^2
A smallblock chevy dressed with all accesories is about 550lb/s from what I understand.
The T-5 transmission is about 120lbs I think. However the clutch assembly and hydrolics adds another 20lbs I believe.
Typical 700r4 is about 170lbs with fluids and torque converter. I can lift a loaded 700r4 with mild difficulty to move it around. Don't ask me to carry it to the neighboors though!
_________________
Camaros
wow thats cool info, is there a site that i can check out that you got it from? thankyou
I think the T5 is 98 lbs. That is the number I got when I was doing my T5 swap in a 3rd gen (before T56's were readily available). But, either number is probably close enough.The T-5 transmission is about 120lbs I think. However the clutch assembly and hydrolics adds another 20lbs I believe.
Quote:
Dry T5 itself is 85lbs. I shipped my old one to a guy down south.Originally Posted by trackbird
Quote:
Still better than most. Originally Posted by Gunny Highway
How do those numbers stack up with other sports cars, and new cars of today?
Quote:
I must have over-crated mine. I think my shipping weight was 104 lbs (I sold it to a guy in NY).
That is quite possible, I was sure that 120 was too high, but 85 may be correct, I may be a little off.
Thats why I added a qualifier to my post. I wasn't sure because I really haven't done to much work with a T-5 transmission. Most of my expereince has been with 700r4 trannies.
If you say they are about 100lbs then I agree with your statement.
