Do the 6 cylinder Gen 3s have same rearend as 8s?
Old Dec 28, 2003 | 09:57 PM
nuck's Avatar
Are all GEN 3 10 bolts the same?
Old Dec 28, 2003 | 10:17 PM
mako350Z28's Avatar
Should be, except for whatever gears are in it.
Old Dec 28, 2003 | 10:31 PM
Black6SpdTA's Avatar
Yep, and posi/open.
-Corey
Old Dec 28, 2003 | 10:58 PM
unvc92camarors's Avatar
Originally posted by Rippin92RS
Yep, and posi/open.
-Corey
yea, those 1 wheel tire-fryers aren't that much fun
Old Jan 1, 2004 | 01:57 PM
Stephen 87 IROC's Avatar
There are a few differences but they have nothing to do with the engine. Over the life of the third gen, GM changed the casting on the 10 bolts. The 1986-1992 have the better castings. The earlier models are weaker and depending how tight the torque arm bolts were tightened, you could deflect the housing and cause the pinion bearings to fail prematurely.
The strongest third gen diff offered in normal production was the Australian Borg Warner 9 bolt. Nothing internal is the same as a 10 bolt but all the external mounting hardware is the same. The ultimate find is the Dana 44. It was used in the SLP Firehawk and use'd to be available from the GMPPC. If you can still find one, they price is almost the same as buying an aftermarket bolt-in 12 bolt or 9". The Dana 44 used an 8.5" ring gear.
Old Jan 1, 2004 | 04:38 PM
Evil Turbo SS's Avatar
What years can you find the "9 bolt" and who makes upgraded parts for it. Whats the ring gear size?
Old Jan 1, 2004 | 06:59 PM
The ring gear size is 7 3/4" but there's more to it's strength than just the ring gear size.
http://www.difftechnics.com/9_bolt_home.html
cmsmith
Jun 4, 2015 07:35 PM
R@mpage
Apr 20, 2015 10:02 AM
Chris Anderson
Jan 27, 2015 08:30 AM
ddr698
Jan 9, 2015 10:05 AM
