Did all IROCs have disc breaks????
Old Jan 7, 2005 | 02:16 AM
SSnthe10s's Avatar
i was just wondering i might be getting a parts car and i would like disc breaks. and did these come with the 9bolt by any chance?
thanks
Old Jan 7, 2005 | 02:59 AM
stevem's Avatar
Re: Did all IROCs have disc breaks????
no they did not,i belive it has to have the borg warner(9 bolt) rear end to have discs.
Old Jan 7, 2005 | 03:28 AM
hairbear's Avatar
No, like the guy above said except 10bolts could also have had "disc brakes".
Heck IROCs had some many combos back then. You could have got 305s,350s,TPI,4bbl,non posi,posi,5-speed,auto,steel hoods,plastic hoods,etc.
Old Jan 7, 2005 | 04:45 AM
SSnthe10s's Avatar
this one had a tpi 305 with a 700r4. im praying its a 9bolt.
Old Jan 7, 2005 | 09:00 AM
87DJP2001's Avatar
No, not all IROC-Z had disc brakes. What you may get is a 10-bolt 2:73 rear with drum brakes.
This was the common set up for a 305 TPI and the 700R4 Auto. All 9-bolts with Disc came on 350 cars (J65) and 305 TPI's with Manuals & (G92) options.
Old Jan 7, 2005 | 03:07 PM
RedIrocZ-28's Avatar
What year man? Mine is an 89 and it did have a 9 bolt and Disc brakes. DJCobols car is an 89 and had a 10 bolt and Drum brakes. '89 is the most likely to have a 9 bolt and discs
Old Jan 7, 2005 | 03:26 PM
87DJP2001's Avatar
What engine do you have in your car??? (also what is "it did have")??
And nothing is more wrong then "89 is the most likely to have a 9-bolt and discs".
The 9-bolt came only in 350 cars with the
2:77 std & 3:27 with G92 option and 305 TPI Manual cars came with a 3:45 G92 option. Disc brakes RPO J65 was also a option but required on 350 and G92 cars.
So your statement is wrong and incorrect. Do some reseach for facts and not what is "likely".
Old Jan 7, 2005 | 05:15 PM
stanghunter211's Avatar
Count the bolts on the diff cover, it couldn't be simpler. But depending on year, a 9 bolt doesn't guarantee you "good" disc brakes. If you get an early 9 bolt, say 86-88, they still had the cast moraine calipers. 89-90 was the good stuff, 91-92 went back to the 10 bolt, but retained the PBR aluminum calipers.
Will
Old Jan 9, 2005 | 03:04 PM
METHOD_MAN's Avatar
first off the 9 bolt aussie rear end is junk....and an 89 is most likelyyyyy???? what? what do you mean most likely....and stang hunter how do you figure that the 9 bolt rear discs in 88-90 are better than the 10 bolt disc in 91-92?
Old Jan 9, 2005 | 03:16 PM
9 bolts are stronger than 10 bolts. This has been discussed hundreds of times
Old Jan 9, 2005 | 05:04 PM
SSnthe10s's Avatar
jeez where are u getting your info
Old Jan 9, 2005 | 05:13 PM
87DJP2001's Avatar
Before and up to 1988 both 9 & 10 bolt rears had the 10.5 rotors and iron calipers. In 1989 the 9-bolt had the 11.655 rotors and Aluminum PBR calipers, the 10-bolt had no changes. Now 1990/92 with the 9-bolt discontinued the 10-bolt now had the same 11.655 rotors and PBR calipers.
Bxlt1
Sep 29, 2015 03:18 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
