Delayed Throttle Response?
Old Aug 20, 2005 | 01:24 AM
LesPaulGoth's Avatar
I have a 1990 IROCz 305tpi.
Now, my question is:
Is it normal to have a half second delay in throttle response? Reason I ask is that I always expect the car to take off but theres a slight delay when I step on it, and then it just seems like its not pulling as hard as it should.
Heres what happens in sequence:
Pedal goes down....rpms shoot up...THEN car accellerates faster.
Its got Summit Shorty Headers on it, Hedman YPipe, Flowmaster dual out muffler, TB bypass, Gutted airbox, 10 degree timing advance, ACCEL Coil and 8.8mm wires. IMO I think I have a fairly free flowing setup, and I just think it should be responding right away and pulling a tad harder. Could this be due to a vacuum leak somewhere? If so, where are common vacuum leaks?
Old Aug 20, 2005 | 01:32 AM
MasterEvilAce's Avatar
Re: Delayed Throttle Response?
is the tranny downshifting, or does it feel like it's slipping at all, and then grabbing?
Old Aug 20, 2005 | 01:40 AM
Runin2Nite's Avatar
sounds like the trans to me... ur rpms should be bounceing if its a vac prob.
Old Aug 20, 2005 | 09:46 AM
Ehh, I was afraid you'd say that. Its not really slipping or downshifting, but its like at times, the rpms shoot up 1000-2000 and I can hear the engine revving higher, but I get no response for a half second.
Old Aug 20, 2005 | 10:27 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Have you checked the timing? If it the initial advance is retarded it will make the car lazy and sluggish. Just another suggestion besides the tranny...
Old Aug 21, 2005 | 10:41 AM
Yes, timing is accurate, and was advanced to 10 degrees not too long ago.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Tarizza
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
