Cracked Flexplate
Old Apr 14, 2004 | 02:54 PM
rudy's Avatar
Cracked Flexplate
Anyone had their flexplate crack up on them?? Car developed a noise that initially sounded like a lifter tick. After a 130 mph run down the freeway, it got a lot louder. Pulled the dust cover off, and low and behold, cracks from the outside in, and all around the center section. Just curious if anyone else has had this happen to them.
Old Apr 14, 2004 | 04:53 PM
Dave89IROC's Avatar
Re: Cracked Flexplate
not uncommon
new one is $30 at Autozone
Old Apr 14, 2004 | 08:10 PM
aklim's Avatar
How are the teeth? Check the starter too. Make sure that it is fine or the starter might chew up the new flexplate too. Ask me how I know.
Old Apr 14, 2004 | 09:22 PM
TheGreatJ's Avatar
I tore the center out of mine shortly after I swapped in the 355. Replaced it and the tranny died 6 months later (which I used as an excuse to swap in a T56.)
Old Apr 14, 2004 | 09:48 PM
porkyzilla's Avatar
has anyone expierenced rpm surging because of this??? or rough starting espeically in 4th gear it surges real bad
Old Apr 15, 2004 | 07:42 AM
rudy's Avatar
THanks for the replies. I think I will get a aftermarket piece so this doesn't happen again. Planning on a blower soon.
Old Apr 15, 2004 | 07:05 PM
TheGreatJ's Avatar
Rough starting yes, because the ring gear doesn't line up with the starter like it should.
I didn't have a problem with surging but anything's possible...and since 4th gear is when the TC locks up, it makes sense that it would be worse then.
magman
Apr 15, 2016 03:08 AM
RUENUF
Mar 13, 2016 03:37 PM
David Dempsey
Mar 12, 2016 12:42 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
