COLD AIR INTAKE for TBI V8's
Old Jan 17, 2005 | 02:35 PM
huskyfever03's Avatar
ive never seen one of these for a TBI so i thought it was kinda intresting. im prob the only one who hasnt seen one...and in the pic does anyone know where i could just buy the black turbo lookalike plastic thingy. ivee seen them on S-10s n wonder if they would fit my 91 RS TBIv8... http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
Old Jan 17, 2005 | 08:36 PM
PyRo9862's Avatar
Re: COLD AIR INTAKE for TBI V8's
I doubt it will do much if anything for you. I don't see where the "cold air" is comming from, it's still sucking in the engine bay air an open element would, possibly from a slightly cooler spot. The more interesting ones use the tpi airbox to get cold air, or even make up ram air boxes to go behind the grill (although the ram air probably doesn't do much).
Old Jan 17, 2005 | 10:09 PM
FryedClutch's Avatar
well if ya really want to pimp your ride with a cai then get a street scoop
since the tb for that is baisically like a carp i dont know why it wouldnt work
but then youd have to cut a hole in your hood
but i think the scoops look sweet as hell
but thats the only ram air cai i can think of for tbi's
Old Jan 18, 2005 | 09:41 PM
Damon's Avatar
Aftermarket 14x3" drop-base open element air cleaner plus a cold air kit from these guys:
www.ramairbox.com
You'll probably like the end result more, but it'll cost you a fair bit more, too.
Check out the TBI forum over on Thirdgen.org for more info. The air cleaner assy. isn't the main restriction on a stock 305 TBI engine.
Old Jan 21, 2005 | 09:36 PM
buzz12586's Avatar
I took one of those kits and connected it to the a TPI air intake and it looks sweet and works great. I'll have to see if I can dig up some pics.
Old Jan 22, 2005 | 02:09 PM
njspder's Avatar
teh first thing to overcome with tbi/carb is the volume of air, not the temp.
teh stock air box is a complete POS.
the best and easiest fix is a flat base 3x14 open element air cleaner. if you want you can also run a 2.5x14 open element and a K&N extreme flow lid.
later
tim
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
