code 43 after rebuild
Old Mar 14, 2004 | 07:08 PM
pigsticker's Avatar
I'm getting a code 43 (knock sensor) since my rebuild. I put in vortec heads good for 550 lift, cam with a little over 500 lift,SDPC TPI intake, Edelbrock HI-FLO runners, long tube headers, new pushrods, new lifters, double roller timing set, New rings, New mains and rod bearings. ported plenum, 52mm throttle body, 24# SVO injectors and other stuff. Anyone else ever had this problem. I've got the timing set at 10 and it cranks up fine unless I've been running it then when I kill it, it acts like the timing is advanced to much or the motor is so tight it doesn't want to turn over. I've got a new battery and it acts like it gets drained after trying to crank it after running the car. I just wonder if the code has anything to do with this? One other thing, while driving the trouble light will go off and come back on after about a minute. Any ideas?
Old Mar 14, 2004 | 07:33 PM
Rice Killer87's Avatar
what kind of chip (prom) are u running? the cam might be the cause of the sensor code.
for the slow turnover,try setting the timing to 8*. if that doesnt help,then it may just be heat soak on the starter,typical 3rd gen problem.
hope that helps
Old Mar 14, 2004 | 07:44 PM
pigsticker's Avatar
It is a custom burned chip and I was running 8* before I set it at 10*.
Old Mar 15, 2004 | 12:49 AM
aklim's Avatar
Who burnt it and why are you going that high? it should be 6 deg.
I was getting that code but it turned out to be the wiring was bad. Check the connector. Did you put teflon on the threads of the KS?
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jazsun
Dec 29, 2014 12:14 PM
91Bird305
Aug 5, 2002 01:39 PM
