Code 36!!
Old Dec 4, 2003 | 06:26 AM
Brit Iroc's Avatar
Code 36!!
Ok, so I've just checked my TPS voltage, fired the car up and got a code 36 register!. Cant find that one in the book. Any ideas guys?. Its an '87 350 TPI. Thanks.
Old Dec 4, 2003 | 07:40 AM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
I think Code 36 is for the MAF burnoff relay.
Old Dec 5, 2003 | 12:20 AM
90rocz's Avatar
Yeah, that's right. It's the self cleaning circuit, check the relays. It will slow the resonse to changes in driving conditions seen at the computer.
Old Dec 5, 2003 | 04:25 AM
Brit Iroc's Avatar
Thanks guys. Is that relay at the back of the engine bay on the drivers side mounted on the bulkhead?.
Old Dec 5, 2003 | 05:06 PM
Rice Killer87's Avatar
yea,its 1 of those 3 or 4 back there.
1 is MAF Power relay
1 is MAF burnoff relay
1 is fuel pump relay i think and im not sure what the other is...forgot
hope that helps
Old Dec 5, 2003 | 07:31 PM
90rocz's Avatar
cooling fan(s)
Old Dec 7, 2003 | 07:30 AM
Brit Iroc's Avatar
I found the relays. They look the same...are they?. Cleared the code and tried the car again today. It never missed a beat. Started it and stopped it a few times before I went out...no code. Drove the car for quite a few miles got home, stopped it started it...code 36 set again!. My question now is how does the MAF burn off problem affect the cars performance?. It felt better than ever today. Can I swap those 2 relays to test for the problem?. Thanks
Old Dec 7, 2003 | 08:56 AM
90rocz's Avatar
If the MAF gets dirt build up, it will dull it's sensitivity to changes in air temperature slowing the ECM's response to throttle changes.
Old Dec 7, 2003 | 01:24 PM
MasterEvilAce's Avatar
I believe fuel/MAF relays are the same
just switch them
might want to shake the relays, too, and see if you can hear parts broken inside
don't forget to clear the codes(disconnect battery for 30 seconds or so) before starting the car, after changing the relays, to make sure you're not bringing up old codes
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
