code 33 how do I test my MAF sensor?
Old Jul 2, 2006 | 08:40 PM
355yellowroc's Avatar
Got a code 33 yesterday. Is there anyway to test the MAF sensor or relay?
Or is it probably just toast?
Thanks,
Troy
Old Jul 2, 2006 | 10:12 PM
89Vert's Avatar
Re: code 33 how do I test my MAF sensor?
save target as
http://www.moates.net/files/6)%20Mis...s/TPIcodes.pdf
Old Jul 3, 2006 | 12:11 AM
CamaroSS30thAnn's Avatar
Originally Posted by 89Vert
for reference its on page 20 and it will help alot if u knew how to use the chart
but anyways this is what i picked up from a quick search
CODE 33
Trouble Code 33 indicates that the Mass Air Flow (MAF) sensor is reporting more air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
The conditions for setting this code are:
no Code 21 or 22 (TPS Error) present, and
the air flow reported is > 40 grams per second, and
TPS indicates < 10% throttle position, and
the engine speed is 1400 RPM or less, and
the above conditions exist for over 5 seconds.
Typical causes for this code include:
1) Faulty MAF-to-ECM connection
2) Exceedingly noisy spark plug wires
3) Poor routing of MAF harness (i.e. near coil packs)
4) Maladjusted TPS sensor
5) Defective MAF sensor
6) Defective ECM
Incorrect voltage level at
terminal C on the MAF sensor. Should be 0.5 volts at idle, 4.7 volts at wide open throttle (WOT)
Faulty or loose wiring and/or connections at the MAF sensor.
Faulty MAF sensor.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
QuickSilver02
Apr 7, 2015 11:12 AM
jj_burchiel
Mar 21, 2015 12:51 AM
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Sep 13, 2002 03:35 PM
