code 32? help!
Old May 8, 2004 | 04:33 PM
SSnakeEater's Avatar
code 32? help!
my friend has a 92 TBI 305 LO3.
he is getting a code 32. which is EGR system failure.
we dont know where to start. What should we look at or test first? EGR solenoid?
Old May 9, 2004 | 09:14 PM
ttt
Old May 10, 2004 | 12:01 AM
xeroxed's Avatar
check the vacume lines got to the egr solenoid and the egr valve. then check electrical connectors. it might also be a short or bad egr valve or egr solenoid or possibly the ecm.
Old May 17, 2004 | 10:38 AM
white91gta's Avatar
if it is the egr valve...put a blockoff plate in its place and get rid of the POS
Old May 17, 2004 | 07:51 PM
Rice Killer87's Avatar
u can test to see if its the EGR valve or not...with the car semi-cool start it up and let it idle,take ur hand and push up on the bottom (up underneath) plate of the EGR valve up. if it stalls or runs crappy,thats not the problem,if it stays running normal (should be running crappy) when u push it up,then thats the problem.
yes,check the vacuum lines/line to it as well.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
