code 32? help!
code 32? help!
my friend has a 92 TBI 305 LO3.
he is getting a code 32. which is EGR system failure.
we dont know where to start. What should we look at or test first? EGR solenoid?
u can test to see if its the EGR valve or not...with the car semi-cool start it up and let it idle,take ur hand and push up on the bottom (up underneath) plate of the EGR valve up. if it stalls or runs crappy,thats not the problem,if it stays running normal (should be running crappy) when u push it up,then thats the problem.
yes,check the vacuum lines/line to it as well.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
