code 23 on 305 TBI 89RS camaro
Old Apr 25, 2006 | 12:27 PM
ad356's Avatar
m/c solenoid circuit open or grounded. what is an the m/c solenoid and what does this code mean/what sensor needs to be replaced? any help would be appricated
Old May 5, 2006 | 08:49 AM
1987IROC350's Avatar
Re: code 23 on 305 TBI 89RS camaro
23 Manifold Air Temperature (MAT) sensor
Faulty MAT sensor.
Faulty or loose wiring and/or connections to the MAT sensor.
I copied and pasted this off www.iroczone.com/specs/TroubleCodes.htm
Old May 6, 2006 | 09:28 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
M/C would be mixture control solenoid on a carburetor car. The book you're using is outdated. The correct problem on your car is described by 1987IROC350 above. The wiring for your MAT sensor is shorted or open, or the sensor has failed.
Old May 6, 2006 | 10:04 AM
Dave89IROC's Avatar
make sure the sensor is plugged in(it is the one in the bottom of the air cleaner)
Collector Car
Jan 5, 2015 10:58 AM
Dec 5, 2014 11:42 AM
Dec 1, 2014 08:08 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
Jul 4, 2005 05:00 PM
