clicking when attempting to start
Old Feb 20, 2003 | 02:08 AM
irocz4life's Avatar
i have an '88 iroc-z, quite often, but not all the time when i try to start it there is a clicking noise, and im not sure what it is, it will just click and nothing, sometimes i have to turn the key up to 10 times before it will finally turn over, any suggestions?
Old Feb 20, 2003 | 05:43 AM
AlabamaOutlaw's Avatar
Could be your battery or alt.
Work the cables on your batt. and see if just aint gettin fire
has your alt. ever been rebuilt?
If so was it done in the last year?
alt's are really bad to go out on camaros
if it keeps doing it after you have worked the batt cables, then take it to a shop.
Old Feb 20, 2003 | 08:51 AM
HardDriver's Avatar
Yep, mine did the same thing - it was a bad ground. Check all your battery connections to and from the starter.
Old Feb 21, 2003 | 05:23 PM
89iroccamaro's Avatar
my car did the same thing i found out that the starter was bad. so i bought a rebuilt and the same thing happend 1 month after. i found out that my y pipe was running right next to the starter and it ended up frying the motor or solenoid so the only way i was able to cure the problem was to get a really good starter and put that thermal wrap around it. Havent had a problem ever since
Old Feb 21, 2003 | 08:08 PM
gun4hire's Avatar
Definitely check the terminals first for corrosion, etc. Do the cheap stuff first!
DirtyDaveW
Dec 1, 2016 05:37 PM
HuJass
Aug 29, 2002 02:30 AM
HuJass
Aug 27, 2002 09:58 PM
HuJass
Aug 27, 2002 09:53 PM
HuJass
Jun 27, 2002 11:04 PM
